1hz oil pressure
Long story short, need a new port to use on my 1hz to read true oil pressure. Anyone ever done this before, If so where did you go to get the reading?
Can you put in a "T" fitting? One for factory and one for whatever you want.
What happened was the port became compromised and had to be ground flat drilled, tapped and bunged up, tapped in underneath the oil filter for the turbo feed line, t piece on that and doesn't read oil pressure at all (saas 12v gauge or speco mechanical gauge)
