For Sale 1HZ/1HDT denso alternator 120 amp
mudandrock
Back 40 Cruisers
Supporting Vendor
Montana
Website
back40imports.com
120 amp 12 volt alternator. Brand new, $520 shipped to lower 48. If you have an early model with the round style plug, I can supply that as well for $20.
FYI: this alternator is bigger than most and requires a bit of mechanical acrobatics to mount in a 80 series. Some replace the mounting bracket with the 100 series style, I think they run about $15. I’ve never had an issue though myself.
Would it fit a HZJ75?
Yes it will fit. There are two styles of bracket, part number 16381-17020 fits larger alternator and 16381-17010 fits the smaller style. If you have the smaller style it will still work (I’ve done it many times) it just makes installation less straight forward because you have to loosen the two bolts that hold it to the water pump in order to get the main top 12mm head bolt to start. Once mounted, tighten those two 14mm bolts on the bracket (29 ft lb) and you’re done.
PM sent.
