SOLD 1HDT and 1HZ Injection Pumps
mudandrock
Back 40 Cruisers
Supporting Vendor
Montana
Website
back40imports.com
1HD-T injection pump. Fully rebuilt, bench tested. $1850
1HZ Injection pump w/HAC. Fully rebuilt, bench tested. $1650
My goal is to always have at least one of each of these on the shelf at all times; therefore, pumps come with a core charge. If you send me your pump in advance, there is no core charge.
Ships from Kalispell, Montana.
Payment: PM for options
An chance you have a FT pump for a rebuild? Don't mind paying the core charge to avoid downtime.
so i can remove that bolt and reuse. I was under the impression it was a 1 time use bolt. tks. Now to find a used tool to buy :)
The tools are still available new and I can supply if you need. A local diesel shop may have something similar that will work. If you’re talking about the plug for where the tool is installed, it’s reusable, it’s only the crush washer that needs replacing.
