My IHD-T injection pump is leaking. It is from a '95 LC80 and was swapped into a 1991 HZJ75. I noticed some diesel fuel leaking in the area of the ACSD actuator rod. Local shop said I need to have the injector pump taken out and rebuilt. That is quite an expensive rebuild. On the other hand someone who is quite familiar with this problem said it is a worn bushing for the ACSD actuator rod and that it is easy to fix, without actually having to remove the IP. Anyone else familiar with this? I've attached a photo. I can see diesel flowing under the spring in the picture and dripping from the underside of the spring. It's dripping at a rate of 1 drop every 2-3 seconds. The engine is running fine. I have a good video of it but don't seem to be able to upload the video.
