I've got a nasty sounding noise in my car - have a listen: http://www.youtube.com/watch?v=Gvu6JBMBJNs
The noise is persistent in neutral, every gear, and every gear with the clutch in. Comes in at just before 3000RPM as the video shows, and ends ~100RPM later.
The noise/vibration also comes through the clutch pedal. At 3000RPM with the clutch in, the noise gets heaps worse and I can feel it through the pedal. If I'm driving and change gears above 3000RPM, there's a sharper version of the sound as the clutch pedal goes in and out.
Noise History
Came on suddenly one afternoon while accelerating past 3000RPM. It wasn't there the day before... I first noticed it a few weeks after the new harmonic balancer was installed, but before the new clutch was put in (see car history below). This would seem to rule out the clutch being an issue.
Car History
The engine (short block at least) was completely replaced with a reconditioned model at the start of 2012. Fuel pump was overhauled at the same time.
Around October 2012 the fuel pump was modified to suit my Gturbo, injectors were fully reconditioned (shop can handle the 2 stage design) and I had the car dyno tuned.
A few weeks later I had a new harmonic balancer installed as the old one failed. A month after that I got a new HD clutch installed, along with new flywheel & spigot bearing.
Troubleshooting
Haven't done too much myself due to limited mechanical knowledge...
It stumped my normal mechanic (the guys who installed harmonic balancer and clutch). Also stumped a friend of mine who's a diesel fitter. Both played around with the clutch pedal.
One diesel specialist in town reckons he'd heard it before in other 80s, and it's the timing gears chattering (either around the timing belt, or further behind - where the injection pump and oil pump drive gears are located). I forgot to tell this guy about the feeling through the clutch.
Another diesel specialist (guy I got the car tuned through), reckons it's something to do with the timing in the injection pump, and nothing to worry about at this stage. Again, he only listened to the engine and didn't feel the clutch.
This is the closest issue I could find while searching the net for timing noise: https://forum.ih8mud.com/diesel-tech-24-volts-systems/228428-1hd-t-noise.html.
Another guy on an Australian forum reckons his failing harmonic balancer created very similar symptoms to what I'm experiencing.
I've got the car booked in at the Toyota dealer in town for next Tuesday. Hoping I can get a master mechanic or someone with a bit of experience with this engine, who may have heard it before.
Sorry for the monster post, and any help would be very much appreciated!
Noise History
Car History
Troubleshooting
