SOLD 1FZ engine & transmission - 187k miles - CO
1FZ-FE engine with 187k miles on it. The engine is still installed in the 93 Toyota Landcruiser FZJ80 so you are welcome to come hear it run before I pull it. I'm located in Gunnison, CO.
Compression test showed all cylinders are close to 150 psi (145 are the lowest and some are just above 150). My elevation is almost 8,000 ft. Video below shows it running and compression test.
$900 for engine with accessories
+ $300 for transmission (I will not sell the transmission separate until the engine is sold)
I can also include the wiring harness and ECU if you want those as well.
full
full
full
full
