- Location
- United States
1997 Lexus LX450 215,000 miles $7,500 OBO or Interesting Trades
Factory E-Lockers
Wheels and TIres
o 37 x 12.50 R 16.50 Goodyear MT – Hummer Military Tires w/ spare
o U.S. Wheel 70-6860 - U.S. Wheel 70 Series White 8-Spoke Wheels
o Wheel Spacers – Aluminum 1.25”
Body and Interior
o Front fenders cut to fit tires, edge redone w/ angle iron inner fender redone to all look stock (as of 5/10/11 DS is done PS needs done – but will be done soon)
o Rear fender openings cut, flanged over and welded
o Flexy flairs
o Lower body lined w/ Durabak – Needs to be redone since wheel openings cut out and doors changed
o Started to paint Flat Olive Drab Green – Magic Paint – will finish in next couple months if still have truck
o Interior floor lined w/ Durabak
o Additional sound deadening on floor and roof
o Cloth seats, door panels, headliner, carpet out of ’94 Land Cruiser
Front Suspension
o J-Springs
o 1-3/8” Spring spacers
o MAF 3” drop brackets
o Rancho RS9000XL 14” travel shocks
o Custom extended front shock mounts
o Swaybar Drops
o Swaybar Disconnect brackets
o Stainless Steel Extended Brake Lines
Rear Suspension
o J-Springs
o Custom extended rear shock mounts
o E-brake cable and other cables lowered on drop bracket to allow full travel w/o destroying lines
o Reinforced trailing arm mounts at frame
Front Bumper
o Frankie’s Off-Road Custom built w/ stinger
o 2”OD tube
Rear Bumper
o Custom owner built based on flipped factory hitch
o 3/16” plate w/ ¼” plate top
o Exhaust exits through bumper
o Receiver hitch w/ front accessable pin - but receiver is completely protected
Exhaust
o Magnaflow 3 way spun catalytic converter
o New O2 Sensors @ about 175K miles
o Mandrel bent tubing over frame
o Cherry Bomb Turbo Muffler
o One weak point is it has some flex tubing in part of the exhaust which works, but would be better if replaced with solid exhaust tube.
Sliders
o Owner built rotating sliders
o Out-riggers are 2”x2” x ¼” wall tube
o Main body is a trapezoid shape of 6”, 3”, 3” and 2” x 3/16” plate
o Slides over rocks easier than tube sliders, and gives maximum clearance
o In down position they are lower than step sliders, and provide a great step in . Makes getting into tall truck really easy.
Custom skid plate
o Extends to sliders at center mounting point.
o Even with bottom of frame except at t-case where it slopes down to clear
o Reinforced w/ tubing
1” Body Lift
Dual battery set-up w/ relocated washer bottle
Rock lights
EGR Valve and VSV replaced 2 years ago
All 4 brake rotors replaced @ 165,000 miles
Front end rebuild @210,000
New 100 Series Pads @210,000
Issues
• Rear defroster doesn’t work
• Rear quarters need a little straightening
• Spare tire is bad – but will be replacing soon.
I bought this truck with 163,000 Miles and it was a one owner truck. I’ve had it for 6 years and have simply become bored having the same truck for so many years. No known mechanical issues, and the truck drives good down the hwy at 75+. Still rides comfortably despite its height and 37” wheels. Off-road with the lockers and long travel suspension the truck is simply amazing. Locked 80’s are good, 37” tires and 14” travel shocks take this truck to a higher level. You can ignore the dent in the PS doors, my brother is shipping me new ones shortly. It has been used for it's intended purpose on the rare occasions I have time.
YouTube - Disney 2011
I’m open to trades or partial trades – Just looking for something different from this, maybe something unusual. 1st Generation 4 Runner, FJ45 Wagon, FJ55, Diesel Mercedes (5cyl from 70’s 80’s), CUCVV, Unimog, Duce and a Half, Crew Cab, Toyota RV / Chinook, Samurai, Vanagon Sycro or Westy or ??? Not in any rush, and plan on continuing to improve the vehicle (finish paint ect) as if I'm keeping it, just wanting to see if there was something interesting I could trade for different - or $7500 cash and I'll go buy something different
PM or email rallybug@yahoo.com
Factory E-Lockers
Wheels and TIres
Body and Interior
o Flexy flairs
Front Suspension
o J-Springs
o Swaybar Drops
Rear Suspension
o J-Springs
Front Bumper
o 2”OD tube
Rear Bumper
Exhaust
Sliders
Custom skid plate
1” Body Lift
Rock lights
Issues
