Trade 1997 Landcruiser CE...Minnesota
i know. wtf. i'll repost later.
I'm having problems with the posting. I will fix it later when I get home.
Sorry. PM me if you have any questions.
Thanks.
Well,
Here's my original posting. It's no longer on craigslist.
Are you looking to up size or upgrade to something bigger? Do you have a growing family and need more seating?
Well, I may have a solution for you....
I have my 1997 Toyota Landcruiser Collectors Edition that I'm looking to downsize to something smaller.
My Landcruiser has approx. 225K miles. I run mobile 1 full synthetic oil. I mainly use nothing but oem toyota factory parts for any fixes.
It has a clean title, titled under my name...and yours should be titled to your name as well. I have kept my Landcruiser up to par on
maintenance. If it needed anything major, I had it fixed. I trust this truck and have no hesitation of driving it to California and back. Landcruisers
are known for their versitility through any type of weather and most importantly....reliability.
Here's what Kelly Blue Book Rated my truck for value.
-Excellent
$7,743
-Very Good
$7,393
-Good
$7,193
-Fair
$6,293
My Landcruiser is in good condition, but I will consider reasonable offers.
I am seeing if there are any interests out there for an "even trade". I'd like to do an "even trade" for any of the following:
-Toyota Tundra xtra cab/double cab
-Toyota Tacoma xtra cab/double cab
-Toyota Pickup xtra cab
-Toyota T100 xtra cab
Your trade must be 4x4 with xtra cab and up, have good heat/AC. I prefer it have pw/pl, cc, tilt, tow pkg, and automatic transmission would be nice. But 5spd is ok too.
High miles ok. Your vehicle must run well, as mine does.
HAS NO FRONT OR REAR LOCKERS.
I have owned it since November of 2009. It had approx. 177,000 miles when I bought it.
I am the 3rd owner.
1st owner sold it at 35,018 miles. 2nd owner sold it at 177,000 miles.
I am interested in something that gets better gas mileage, hence the reason for my wanting to trade.
I own 2 SUV's and would rather only have 1.
Since I've owned it, I replaced @190k miles:
-DIEHARD GOLD Battery
-4 New Michelin LTX MS2's
-Toyota Starter
-Toyota AC Condensor and AC recharged.
-Front Birfields
-Front Wheel Bearings repacked
-Front axle rebuild kit (oem)
-Turned front rotors
-Replaced front brake pads (oem)
-Replaced all 4 shocks with Bilsteins.
-@211,000 miles I replaced the front and rear brake pads (oem)
-Replaced front Rotors (oem)
-Replaced all 4 shocks with new oem toyota shocks
-Replaced front wheel Bearings (oem)
-Tune up- replaced plugs/wires/distributor cap, and rotor/belts. Thermostat.(oem)
-Radiator flush. Replaced upper/mid/lower hoses.(oem)
-Replaced front drive shaft u-joints (oem)
-Replace valve cover gasket and oil tube seals (oem)
-Front/Rear axles, Transfer case, transmisssion drain and refill.
-EGR Valve and EGR Valve modulator (oem)
Has great heat and AC.
Over all, the vehicle is in good shape with minor dings and scratches. There are a few spots with surface rust.
These are some specs I found online.
Power and Performance
4.5L I-6 212 HP engine
4-spd auto transmission w/OD
Axle Ratio: 4.10 axle ratio
Fuel Tank: 25.1 gal. fuel tank
Handling and Control
Full-time four-wheel drive
Manual transfer case shift
Permanent locking hubs
Front anti-roll bar
Coil front springs
Heavy duty front shocks
Multi-link rear suspension
Rear anti-roll bar
Coil rear springs
Heavy duty rear shocks
Re-circulating ball steering
4 wheel disc brakes
Front and rear vented disc brakes
16.0 " silver styled Aluminum wheels P275/70PR16.0BSW M+S tires
Aluminum spare wheel/tire
Design and Dimensions
Front and rear mud flaps
1 skid plate(s)
Black front and rear bumpers with 2 front tow hook(s)
Rear step bumper
Body-colored fender flares
Chrome grille
Monotone paint
Maximum Cargo Volume: 90.9 cu.ft. maximum cargo volume
Exterior Length: 189.9 " exterior length
Exterior Width: 76.0 " exterior body width
Exterior Height: 73.6 " exterior height
Wheelbase: 112 " wheelbase
Front Tread: 63 " front tread
Rear Tread: 63 " rear tread
Turning Radius: 20.2 ' turning radius
Gross Vehicle Weight Rating: 6,470 lbs. GVWR
Curb Weight: 4,751 lbs. curb weight
Payload: 1,719 lbs. payload
Max Trailer Weight: 5,000 lbs. towing capacity
Front Legroom: 42.2 " front legroom
Rear Legroom: 33.6 " rear legroom
Front Headroom: 40.3 " front headroom
Rear Headroom: 39.7 " rear headroom
Front Hiproom: 59.5 " front hiproom
Rear Hiproom: 59.5 " rear hiproom
Front Shoulder Room: 58.7 " front shoulder room
Rear Shoulder Room: 58.7 " rear shoulder room
Interior Cargo Volume: 47.0 cu.ft. interior cargo volume
Interior Cargo Volume w/Seats Folded: 90.9 cu.ft. interior cargo volume w/seats folded
Active and Passive Safety
Auto off headlamps
2 door curb lights
Oil pressure warning
Battery warning
Low oil level warning
Key in ignition warning
Low fuel warning
Door ajar warning
Trunk/liftgate ajar warning
4-wheel anti-lock brakes (ABS)
Center high mounted stop light
Driver and passenger airbags
Comfort and Convenience
4 doors
Dual power remote mirrors
Passenger illuminated visor vanity mirror
Day-night rearview mirror
Seating capacity of 7
Front bucket seats
3rd Row seating
Adjustable front head restraints
Center front armrest w/storage
4-way driver seat
4-way front passenger seat
Rear 50-50 bench seats
Adjustable rear head restraints
Center rear armrests
Cloth front seat trim
Cloth door trim insert w/carpet lower
Full cloth headliner
Carpet floor trim
Lighted locking glove box
Dome light
Full floor console
Front cupholder
Dashboard storage
2 seatback storage pockets
Dual door bins
Carpeted cargo floor trim
Carpet trunk lid/rear cargo door trim
Cargo tie downs
Cargo light
Manual air conditioning
Underseat ducts
Auxiliary rear heater
AM/FM stereo, seek-scan
Cassette
9 speakers
Radio theft deterrent
Power retractable antenna
Cruise control
Power with 2 stage unlock door locks
Mechanical remote fuel flap release
Rear child safety door locks
1 12V DC power outlet
Driver foot rest
Retained accessory power
Tachometer
Oil pressure gauge
Engine temperature gauge
Voltmeter gauge
In-dash clock
Trip odometer
Tilt steering wheel
Power front windows
Power rear windows
Power rearmost window activation
Driver 1-touch down
Deep tinted windows
Variable intermittent front windshield wipers
Fixed interval rear windshield wiper
Rear defroster
Flip-up rear windshield
RS3000 Keyless Entry Security system.
Tow pkg
The Bad: The check engine light will sometimes come on, usually during the winter months if I don't let the engine warm up a bit before driving.
If I let the truck warm up, then the light doesn't come on. Even though when it does come on, it doesn't affect the way the truck drives
at all. I usually just unplug the battery for 5 seconds and the light goes away.
I've had the code checked out and it is an "EGR" code. If I don't sell or trade the truck by springtime, I will be fixing the
"EGR" code. This is a quite common problem with this particular Landcruiser. As I already stated....it doesn't affect the way the
truck runs what so ever....not even the miles per gallon. "EGR" means "exhaust gas recirculating". Essentially it is for
emmission purposes.
I feel I have been upfront with as much information that I can. I have no intentions of wasting your time, so please be considerate
and don't waste mine.
Trade is for as-is. No warranties from both parties. You test drive my truck, you like. I test drive your truck, I like...we do a trade.
Essentially, I am looking to trade for something of similar to equal condition and value as my Landcruiser.
I live in the north metro and work in Eden Prairie. I am willing to meet within a reasonable distance.
Please email me if there are any interests. Please include pics of your truck and some info.
I will only respond to emails with a phone number.
Scammers please stay away, and will be reported.
I don't have pics right now but I have a 04 trd 4x4 tundra extended cab with 250k runs like a top, just drove from Detroit to Duluth in November, I am the original owner as well
Craigslist has been going crazy with removing Land Cruiser listings. I bet if you asked them, they would tell us LC's are one of the most scammed vehicles on the market online.
Great looking CE!
PM Sent.
Great lookin rig. good luck, if i had not just purchased another one i would be very interested.
good luck!!
greg
Sorry, A change in plans. The wife and I did not see eye to eye on what my plans were.
So, I'm going to just keep the Fzj80 for now.
Pm'd you.
