For Sale 1994 FZJ80 Lockers, Lifted, Slee Goodies
1994 FZJ80 Lockers, Lifted, Slee Goodies *New Price 9-18-11*
NEW PRICE 9-18-11
Well, it's time to officially put my cruiser up for sale. I bought it as pretty much a play toy to be taken camping, off-roading and light around town duty. And it did all of those things very well. But as it usually does, life changed. I lost my job along with my company car so the LC turned into my DD. And when I got a new job, it was 60 miles away with no company car, so the LC was getting a lot more miles than I had planned. Basically, I've put about 18k miles on her in the last 7 months. She may be big, but she can do the miles, that's for sure. But right now I'm just looking for something smaller as I can't afford to buy 2 cars, and I really don't want to put all these miles on the cruiser. So even though I know I'm going to regret it, it's time to pass her on to someone else who can use her for what she was built to do....
**Update** Price Lowered! Valve Cover Gasket replaced, Mobile 1 oil change, tires rotated, and full chassis lube over Labor Day weekend. Truck is ready to go for a new owner. I've bought my next car and the Landcruiser needs to go. Unfortunatly I dont have room at my new apartment for 2 vehicles. Pretty much looking for a cash sale at this time, but still possibly open to a trade on a sport/sport-touring bike + cash. $7200 OBO Located in Lafayette, IN (1hr NW of Indianapolis). Willing to meet buyer 1/2 way (within reason) for gas $$.
1994 Toyota Land Cruiser $7200 OBO *Lafayette, IN*
  • 171,xxx miles
  • White Exterior/Gray Leather Interior
  • Power Locks, Windows, Mirrors, Moonroof
  • Factory Locking Diffs Front/Center/Rear including Center Diff Lock Switch
  • 35 inch 315/75-16 Firestone Destination MT Tires (aprox. 50% tread left) on custom 16 inch black steel wheels
  • 6+ inch OME/Slee lift
    • Current standing lift height is 6 1/4 inch front and 6 5/8 inch rear - slight stinkbug, but not bad, should level out with an aftermarket rear bumper or front spring spacers
  • OME Competition Series 420/423 lift springs
  • Many Parts from Slee-Offroad Including
    • Front DC Driveshaft
    • Adjustable Rear Upper Control Arms w/New Toyota OEM Bushings
    • Front Adjustable Panhard Bar w/New Toyota OEM Bushings
    • Rear Adjustable Panhard Bar w/New Toyota OEM Bushings
    • Front and Rear Swaybar Drop Brackets
    • Extended Brake Lines
    • OME L Series Shocks
    • Steering Damper
    • Slee Headlight Harness (and silverstar headlights)
  • Castor Correction is in check by using Front Control Arm Drop Brackets along with Yellow Castor Correction Bushings
  • ARB Front Winch Bumper (winch not installed)
    • IPF 800xs Auxilary Lights Mounted on Bumper
  • Safari Snorkel
  • Diff and Trans breathers extended into the engine bay as high as possible
  • Newer JVC Headunit with Integrated IPOD Control and Front Infinity Speakers
    • IPOD Hookup in Glovebox
  • In-Dash Cobra CB Radio installed below JVC Radio
  • Husky Floor Liners for Front and Center Rows (Gray) and Rear Cargo Area (Black)
  • 15lb Ultimate Air Co2 Tank for airing up tires/powering air tools, etc
  • Flowmaster 3-inch Custom Made Cat-Back Exhaust with 50 series Muffler (nice growl around town, but quiet at speed)
  • Custom Fit Seat Covers (Black) for Front and Center Rows
    • Fronts have the Toyota symbol and "Land Cruiser" embroidered in red.
  • I have a box full of spares (u-joints, vacuum hoses, nuts/bolts, etc) plus a spare front driveshaft that comes with the truck
Maintenance Completed -
  • New Radiator (CSF), Themostat, Rad Hoses 08/09
  • Blue Fan Clutch 08/09
  • New Vacuum hoses on EGR System 08/09
  • New OEM O2 Sensors 10/09
  • New EGR and EGR Modulator 10/09
  • New Oil Pressure Sender(30lbs@idle,80lbs@3k rpm) 11/09
  • Trans Flush and fill with Synthetic 04/10
  • Front and Rear Diffs Flush and fill with Synthetic 04/10
  • Cleaned Sunroof Drains 04/10
  • New Air Filter 05/10
  • Alternator Rebuilt 07/10
  • New Alternator Belts and AC Belt 07/10
  • Front Axle service including new bearings 10/10
  • Front and Rear Diff flush and fill with Synthetic 10/10
  • Transfer Case Flush and fill with Synthetic 10/10
  • Valve Cover Gasket replaced 09/11
  • Oil Changed Every 6k miles with MOBIL 1 0w-40
  • Front and Rear Driveshafts, Chassis, and Knuckes (if needed) Lubed every 3k miles
  • Tires Rotated every 3k miles
The Bad -
  • The sensor for the front locker is bad.....The locker locks fine and can be tested, but the light in the dash blinks like its not locked, even if it is - Sensor may just need cleaned, maybe replaced, not really sure, but I rarely use the front locker and it's very obvious from the steering when it's locked, so i've never messed with it - Rear works fine
  • AC needs to be recharged - It worked fine when I bought it, but got progressivley less cool as summer went on and I finally just quit using it
  • Truck currently has a CEL - needs a new vsv
  • There is 1 crack on the top of the dash above the gauges - right in the center , goes front to back, about 4 inches long - was like that when I bought the truck and I've used cleaners and lubes on the dash frequently to try and help prevent other cracks in the future
  • Drivers side seat bottom has cracks in the leather - They are not very noticable with the seat covers, but they are there. The upright part of the drivers seat has no rips or tears, only the bottom cushion. All other leather seats are in excellent condition with no rips, tears or cracks. Front drivers side bottom seat cover also starting to wear from the cracks in the leather rubbing it.
  • There is a small dent in the rear bumper and bottom passenger side of tailgate. Its hardly noticable unless you know its there. Looks like PO backed into a small tree. Also a couple very small dents in the hood, maybe the size of a silver dollar - again, not very noticable and these could probably be pulled out easily
  • There is a crack in the sunroof glass - PO says it was professionally sealed and i've never had any issues with it leaking since I've had it
  • Truck has some very, very minor underbody rust. Mostly just the axles have some slight surface rust on them where the paint has worm through. Has only been through one Indiana winter. The body is completely rust free
  • There are a few "Pin Stripes" and a few minor scratches from branches but they are almost unnoticable (mainly seen on the black pillars between the windows) and could probably be buffed out easily
  • Needs a new speed sensor at the transfer case. Speedo sometimes works, sometimes dosen't. I always have my gps in the truck, so I've just been using it for an accurate speed reading. Does not effect the Odometer....it works fine 100% of the time
Thats about all I can think of for now. I've tried to be very detailed and honest about the truck, I want you to buy it and be happy with it not have any surprises. I would be interested in a trade for a motorcycle in the $3-4k range plus cash. I'd love another Honda VFR, or a Honda RC51, but will consider other sport/sport-touring bikes too. Again, just email me what you have, you never know. No cruiser motorcycles though, please.
If you have any questions, or would like more pictures, please email me at higgin@gmail.com
Thanks,
John
Yep, its still for sale. Generally, I get about 12-12.5 mpg in mixed driving. Best I've gotten on a full tank was 14.2 on a trip to the east coast doing about 65 mph on flat interstate.
Bump for new price today. My apartment flooded and my renters insurance isn't going to cover it (figures!), so I could really use the money right now for some new furniture. Make an offer!
Bumpity!
Here is the only pic that I can find of the rear of the truck. My camera and regular computer got killed when my apartment flooded. So I can't get any pics of the seats or more of the rear of the truck right now. The little dent on the back is in the far bottom right (PS) corner of the tailgate and bumper. Look very close in the pic and you can see that the very bottom right of the tailgate is slightly bent up. The part that is bent is almost behind the bumper. The bumper itself looks exactly like someone backed into a small diameter pole. Just slightly dented in, not creased. Pretty much right above the tailpipe. Its very small and almost not noticeable. Otherwise the back is very clean.
Back to the top. OFFERS?
BUMP Bump bump....
Price lowered again today. $7500 :eek: I really need to sell ASAP! This is a crazy price for a great (LOCKED) cruiser!!
To the top
Its July 4th....I still have the cruiser and furniture that is waterlogged! Make an offer! Need to sell!
Friday Bump!
Back up top!
Trade for a 97 4runner? really good shape 4" lift and 285's. Gets around 17-18mpg and a solid 20 before lift and tires. I have all the parts to put it back to stock. Also have professional CAD plans and material for a very nice custom front bumper. I am near St Joseph, MI
Back to the top
Weekend bump!
