Parting Out 1993\1994 Toyota Land Cruisers
Hello!
Working on a frankencruiser project and I've got tons of parts from two different 80 series cruisers. I've got a 1993 that was white that I completely disassembled and stripped down to the frame. The body was rusted out, but the frame seems to be in good enough shape for my project. Remaining Big Parts:
Engine\Trans\T-Case (1FZ-FE, A442, HF2AV)- Complete and runs w\ECU, high miles, - $800
Front Doors, Missing interior panels, otherwise complete - $60\each
Rear Hatch - Upper portion has the usual rust, handle Missing $50 Lower hatch Intact - $50
Driveshafts - U-Joints in good shape - $75 Each
Rear Axle (Drum Brakes) - $150
Rear Upper Control Arms - $100\pair
Rear Lower Control Arms - $100\Pair
Rear Sway Bar - Complete - $75
Rear Factory Panhard Rod - $60
Front Control Arms - Sale Pending
Front Sway Bar - Complete - $75
Tons of other Misc Parts, already removed sitting in tubs in my basement. Please PM if you don't see what you're looking for here.
Also, I have a 1994 Landcruiser that is the core vehicle of the project. I'm swapping a replacement frame from the '93 under it and swapping in a V8. Which Means for this one I have:
Engine - 1FZ-FE - $500 complete w\ECU
Transmission - A442 - $300 complete w\Torque Converter
I'm located in central Iowa, if that helps. Thanks!
I would need a good passenger side real tail light lense (not the complete light assembly) please.
Thanks
Jan
Center Console armrest (looking for the taller one with padding in gray) ?
Clam Shell cover for around steering column in black ?
-Most of the interior of the grey landcruiser was beyond trashed. The center console was destroyed.
-Let me see if I have a spare steering wheel cover...not sure what kinda shape it's in.
middle dash bezel piece that surrounds the radio. price + shipping to 95672 if in good to great shape.
