yotahed
Diesel Head
- Thread starter
- #61
I just returned from a 2500 km run from Salmon Arm B.c. to chilliwack (450km). and from chilliwack to port coquitlam everyday for a week (70km one way) and from chilliwack to salmon arm to kelowna and back to salmon arm. I played with the boost and fuel small amounts along the way, and found a good all around setting that works well and keeps the egts from going crazy. EGT tops out at 1000 up loooong hills in 4th gear. boost is set at 10-12 psi. Truck ran great, nothing broke lol, the one and only problem was on my way home, the #2 injector pipe at the pump was leaking from the part that screws into the pump itself. limped it home about 100kms, tightened it all up and good to go. One other thing is that with a 30inch tire(245/75-16) and a h55f and 4.88's, the revs are way high for use on the highway as well as the speedo being about 20% high. Revs were about 2600 at 80km/h. A set of 33's went on as soon as i got home, and all is much better. 90-100km/h at 2600rpm, speedo is out about 16% or lower. All in all a good trip, im quite pleased with how it turned out.
Cheers all
Cheers all
