O.k. a I'll bite with few questions:
When you say equal angles: Do you mean that if the trans flange is pointing 3 degrees downward then the pinion flange is also 3 degrees downward?
(in which case it would be wrong and create a bad vibration)
Also, what range do you feel the vibration(MPH) ?
A 6" lift on a FJ62 (auto trans) is going to require axle shims - period.
"My rear flanges are 3 degrees off of perpendicular to the ground each, hence equal angles."
