SOLD 1989 HJ61 12HT Salem Oregon.
Ultra clean HJ61 With 165,000 mi. I bought this from an Air Force Flight Instructor who was stationed in Japan, while there he and a buddy found this and worked on it and then brought it back. This is a list of whats been recently done;
HJ61 Mods since Import to US in 2020
-New Brakes
-New brake booster from 80 series
-New brake master cylinder
-New steering linkage
-Keyless entry
-rebuilt axel hubs
-New ARB bumpers front and rear
-Badlands winch with remote and extra battery
-New Headlights
-New OME leaf suspension
-New OME shocks and steering damper
-New paint just prior to US import
-New gage cluster plastic
-professionally cleaned carpet
-Sound proofing with adhesive 1/8 inch foam insulation (doors and floor)
-new air conditioning fluid type
-rubber fender trim
-new rear taillights and side markers
-CQ quartz ceramic coating and two stage paint correction (use reloaded spray after each wash)
-Oil change just before shipping to Oregon
-New mud terrain tires
-Welded rock frame sliders
-black painted mirrors
-New mud flaps
-Turbo back exhaust with muffler
-New glovebox cover.
Starts instantly. Drives out flawlessly.
Asking $36,000
Whats needed;
Sunroof needs a new motor, Winch is currently operated (I don’t believe it’s been used) by a spare battery and needs integrated into electrical system which is 24V.
Contact me for additional photos. I have many. Cannot add more than 5 here. It’s as clean inside and underside as outside.
Nice, in your opinion since you own it, how's that motor compare to the 60 and 62 motors as far as driveability on the highway, acceleration, going over mountain passes, etc.?
I have not driven any others. The HT12 produces 134hp & 232 ft.lbs. As I understand the gas 6 cyl. are not as capable on the highway. This does just fine. It’s certainly not fast tho.
The 12ht can be tuned up rather easily and to blow the doors off the 2F and 3FE.
Simple mods like turning up the fuel and boost make a huge difference and it’s free.
Turning up pump, better turbo, bigger injectors and and an intercooler can bring some awesome numbers.
184hp and 443ft lbs to the wheels.
Hi, I am interested in talking about the car. I used to have the similar model seen in my prof. pic. i'll shoot you a msg
Tried to send you a msg but your inbox is full....
