For Sale 1989 FJ62 (Oregon)
Southwest Oregon
This is a wrecked 1989 with no sheet metal available at this time
These are a list of Items I have but is not a complete list. I am keeping some items for my own use.
All items are as is and sold where they are. So, if you buy something and I ship it to you and you feel it is not as described then you will be responsible for shipping charges. I will accept paypal or USPS money orders. Most shipping will be USPS flat rate boxes. Their rates are online for the different size boxes. If you want to know shipping on larger items figure them out from 97527. I am not going to box something up, weigh it and then have someone back out.. I don't have time for that. I can get you rough size and weight and let you do the calculations-
This vehicle has 209,000 miles on it and was a go to work/grocery getter for the majority of that time. It is located near Murphy/Grants Pass, Oregon. I'm keeping axles, steering, springs,t-case and other misc. items. I am not in this as a business, just a bad habit/hobby. I will try to get this done in between, family, work, and stuff that takes priority. Your patience is appreciated. Prices are open to negotiation.
PLEASE READ THIS, THESE ITEMS ARE GONE- seats, rear seat belts, carpet (only a portion of the rear), rear cargo panels. DS window controls, grab handles, grab bar in front, DS door glass, headlight trims, tailights and lenses, interior dome lights.
Motor is sold.
Transmission-no problems, no t-case included NO t-case for sale, prefer not to ship $200
Smog pump- spins fine $75
Speedometer/odometer $40
Gauge pod- $50
Y- pipe, surface rust but solid - SOLD
front exhaust pipes, solid $40 for the pair- SOLD
Scrapalytics and associated scrap tubing, - SOLD
Alternator -SOLD
clock-SOLD
Black hub trims- minor rust, need a little resto SOLD
Rear torsion bar and associated brackets but not the stuff welded to the axle $100
Rear axle out of an 88 FJ62 $150
Rear torsion bar out of an 88FJ62 w/o bracket that go to body but the stuff for bolting to the axle $50
Complete as you want it fuel injection system- manifold injectors, wiring harness, etc. $???? negotiable--- MAF Gone 2 injectors gone
Fan shroud-sold
handle bezels-sold
MAF-sold
Left foot rest is sold
Hood prop rod is sold
Dash trims and bezels are gone.
post up other items you are looking for, you will get first dibs- I'll post a price.
Exhaust manifold, one stud broke but it was remove and one shield bolt broke but I drilled and tapped it on the same side, you will need a stud and new nuts- $75
Front mud flaps, one is a little tweaked but usable, some rust on bracket but totally usable, pair $25..
Fuse cover, $15
are you willing to sell steering wheel and front hubs .. shipped to 33122 .. ( have a pic of the steering wheel ? )
I'm sorry, I'm keeping the steering wheel, related parts and pieces and front axle complete for now. Otherwise it would be an honor to sell you parts!!
Dibs on the rear sway bar... How much shipped to 98370? Does it come with all the brackets included in the picture?
Thanks!
Yup
Thanks!
Everything attached to the sway bar in the picture is included, just not the mounts that the tabs slip into then bolt down on that are welded on the axle. I will try to get a shipping quote- either USPS or Fed-Ex..
how are the drivers front door hinges ?
Fine
I think they are fine, all doors still open and close despite being tweaked really bad-
They have a tiny bit of play- with the door open a bit, maybe 1/8" of play in relation the back door, enough to feel a very little bump holding the door and lifting up.
KIEF....! Hey man do you have the little front corner lenses? They are clear. My DS one is busted. Any idea on the condition of the INSIDE of the tranny? Miles etc?
BTW, I saw some guy selling the gears out of a 60 TC. Isn't that a split case like the one I gave you?? That case definitely needs gears! :hillbilly:
And....what about that fan shroud I saw there?? I may get a few doo-dads like the clock and the little plastic pieces for the inside door latches.
You say there are 4 hub trims?? I have hub caps on the back but don't recall ever seeing front caps/trims..??:confused:
I need to come over there!
Tranny ran and drove fine but has 209000, no guarantees for $200
No clear lenses-they got smashed. I have some square headlights tho, one is a Koito!!
Yes, I have a fan shroud, excellent shape, if I do say so myself.
Alternator was a good working unit but I recommend a cleanup and checking the brushes and bearings. Sunday afternoons are usually open. I drive to Meddy too during the week.. That might save ya some money..
