I have looked around the forums and I've seen that this is a pretty common issue with the FJ62.
I still thought it might be best to start a thread, just in case my issue is more complicated than I'm thinking it is.
I have a 1989 FJ62, in average condition, trying to get ti reliable enough for long holiday trips.
While having it parked in my back yard and doing a bunch of small fixes on it, it suddenly stops wanting to start at all. One day it was turning over fine and starting up, the next it just would not power the starter motor. I had done a bunch of small wiring work on the stereo unit and a interior dome light, I had also sprayed some WD40 into the ignition keyhole, as I'd heard this helped with older ignitions being a bit worn.
Anyway now I turn the key and just hear a faint click from the passengers side somewhere near the glovebox. The dash lights come on and I can turn the headlights on etc.
I have used several different batteries to test and the starter motor is only a few months old.
Any advice is appreciated, from my understanding I am going to have to check a few things.
Just a few last questions is someone knows:
Thanks in advance
- check the wiring going from the battery to the ignition
- check the wiring from the battery to the starter
- check the neutral safety switch
- check my ignition switch
- check if the starter has somehow already gone bad
- are there any fuses or relays in the engine bay that could effect this?
- could I have messed up the ignition with the WD40?
- where is the neutral safety switch (i'm guessing under the car)?
- any way to easily check if the starter motor is bad/good?
Thanks in advance
