For Sale 1988 Toyota FJ62 Land Cruiser
Year
1988
  1. 60 Series
Mileage
162078
Color
Gray
Outside Link
https://www.facebook.com/media/set/?set=a.10230718577898748&type=3
1988 FJ62 Mileage 2/27/2023: 162,078
$45,000
Located in Nashville, TN
Selling my family member. 1988 FJ62. We’ve enjoyed this work horse for nearly 15 years, but my work necessitates a pickup. Since purchasing a pickup in 2021, she’s not really been used. Time for someone else to give her some attention that she deserves.
Her story is well documented on IH8MUD.COM (Biomax's '88 FJ2 Build-Up Thread - https://forum.ih8mud.com/threads/biomaxs-88-fj2-build-up-thread.239723/ and 40th Birthday Present - https://forum.ih8mud.com/threads/40th-birthday-present.413612/ ). Here’s a breakdown of her life with us:
Purchased 09/07/2008 from original owner in Northern California. Rare FJ62 with manual locks & winders. Restoration performed from 9/2008-9/2010 by Gary Kardum, Owner of Mudrak Custom Cruisers of Sonoma California.
Photos found at: Facebook - https://www.facebook.com/media/set/?set=a.10230718577898748&type=3
09/08-09/10 Restoration
Fab & Install custom sliders
Front Rotors & Pads & Calipers
ARB Old Man Emu Suspension
New OEM Radiator w/ Upper/Lower Hoses
Alternator Belt
V Belts
Plugs, Cap, Rotor
Front Swivel Kit
Front Wheel Bearings
Flush Cooling
Leather Seat Covers Installed
Winch – XD9000
ARB Bumper Installed
ARB Roof Rack Installed
New Dash Installed
Repaint in Factory Color (removed snake blinders, chrome changed to black)
Changed original Brown interior (including carpet) to Gray
Custom Internal Door Covers
Pro Comp Series 97 Black Wheels Installed w/ BFG AT tires
Solid Rock Off-Road SROR Custom Bumper w/ Dual Swing Outs, Roof Rack Ladder, Hi-Lift Mount, Spare Tire Mount.
Maintenance:
Limited paperwork prior to 2008.
Toyota Summary History 1998-05/2003
08/01 129k miles
Valve Cover Gasket Replaced
New Muffler
New shocks/bushings/steering stabilizer
Front Axle & Knuckle seals
Brake fluid flush
Hydraulic system flush
Replaced Fuel Filter
Tranny fluid changed.
Fuel System Cleaned
Plugs, Cap, Rotor, etc. replaced.
Brakes Clean & Adjusted
Front / Rear Shocks Replaced
07/2011 154,893
Replaced failed Solenoid controlling 4WD system
Replaced fusible link
Window seal, weatherstrip & brake booster gasket replaced.
Oil Change; Alignment
Transmission Fluid Changed
Front & Rear Differential Service
Transfer case service
10/2012 155,795
Brake Flush
Distributor Replaced
Throttle Position Sensor Replaced
Oil Change
Brake Flush
Cooling System Flush/Fill
Front/Rear Diff Serivce
Transfer Case Service
Rotation
04/2016 159,291
Fuel Filter Replaced
Tie Rods Replaced
Alignment
Oil Change
Cooling system serviced
07/2016 159,742
Alternator Replaced – 80 Amp
AC System converted to R134
10/2017 160,831
Oil Change
AC Found Leak at Compressor Housing/ Compressor Failing.
04/2018
Replaced Batteries (2) w/ Interstate 65/850
10/2018 161,392
Oil Change
Replaced Load Proportioning Valve, Rear Wheel Brake Cylinders, Brake Master Cylinder
Brakes Bled
Front disc pads replaced
06/2019
BFG AT KO2 Tires Installed
10/2019 161,751
Oil Change
04/2021
Batteries replaced (warranty)
07/2022 174,207 (error)
Oil Change
09/2023 162,096
Fuel Pump & Relay Replaced
02/2023
Rear wiper blade replaced
Other Upgrades:
09/08 Custom made Vinyl Diamond Cargo Mat
09/10-11/10
Installed Sony Bluetooth CD/Radio, Alpine amp & speakers.
Blue Sea Fuse Block Under Driver’s Seat
Installed CB/FM Splitter, Firestick 4’ CB Antenna
Installed Wired Wagon Ultimate Headlight Harness & Aux Relay Panel
Cibie H1 & H4 w/city light headlamp set installed
Tuffy Locking Console w/ cupholders.
Hella Supertone Horn Kit
Stainless Trays for dual batteries
Installed Rigid 40” LED Bar
Installed removable steering wheel w/ locking security system (original included)
Installed Cobra 75WXST CB Radio
Wagongear AM/FM/CB Antenna Mount
IPF Back Up Light Kit & 840 Series Fog Lights; ARB Bottle Opener
Custom otrattw.com switches for lighting
12 Volt Guy Remote Winch Panel Installed in ash tray slot
Various Bezels/Trim Replaced
Hellroaring Tech Dual Battery Setup w/ Remote Module
Rear Factory Seat Belts (didn’t come with them from factory)
12/10 Wagon Gear Side Panels w Speaker Mounts & Tailgate Lid Powder Coated & Lockable, keyed to Tuffy console
6/11
Tint
Added a 2nd Blue Sea Fuse Block in Rear Cargo Area
Tekonsha P3 Trailer Brake Controller.
Dual 4/7 Pin Trailer Outlet Under Rear Bumper
Installed Speedo Correction Gear – b/c larger wheel/tire package. Ratio Adapter (P/N 800F 1.1555) from CSS (Commercial Speedometer Service) in Sacramento, CA
07/2011
H3R Performance fire extinguisher mounted under Passenger Seat (expired?)
8/11
Man-A-Free Long Range Fuel Tank Added – 38 Gal.
09/11
Upgraded internal lights to LED. Green & Red on Dash
09/11
Lojack installed – battery in fob needs replacement as it’s not currently notifying of movement.
11/19
Replaced Hatch Struts
Includes:
High Lift Jack w Off Road Base, Fix-It-Kit
Rubber & Carpeted cargo mat
Original Wheel
Factory Service Manual
Owners Manual
Extra Fusible Link.
Brackets to relocate light bar to roof rack
Receiver Extension (to extend past rear mounted spare)
Condition/ Issues
2 areas on fenders with hair line cracks in paint. Driver’s window channel paint is failing/flaking. Typical rock chips for 15 year old paint.
All bumpers/sliders need repaint
All chrome coverings need recovering
Gas Tank/Fuel Gage has never been accurate
Window winders have been greased, but could use replacement.
There is a leak somewhere into cabin (driver’s front & cargo) – typical of these Land Cruisers.
Dent on lower rear gate from where it closed on a Nalgene bottle.
Other minor items identified in photos.
Frame is solid and in great condition – see photos.
2017 Service: AC Found Leak at Compressor Housing/ Compressor Failing.
7/2022 Service noted: Transfer case housing “seeping” / Transmission pan “seeping”
Locking pin on side of rear bumper swing out stuck open (doesn’t lock that side fully open – can swing shut)
Rearview mirror cover missing (never had it)
Roof never washed since 2009 w/o rack installed.
All paint needs a good clay treatment, as it went about the last 3 years without being washed.
Original windows – small crack @ driver’s lower corner & has begun delaminating.
