SOLD 1988 FJ62 LS1 Swapped - RDU, NC
Year
1988
  1. 60 Series
Mileage
245000
Color
Blue
This really pains me to do this but i'm going to need something that's more suited for longer drives.
Purchased this truck from another MUD member (@88red) and he did the LS swap along with restoring the frame. You can view his excellent work here:
...and here's what was done to the frame:
Frame was thoroughly cleaned, primed and painted. The notorious rear c-channels replaced, and rust on the rear cross member was cut out and new steel welded. No other significant frame rust or damage is present.
More information can also be found at the original for sale thread:
Details:
  • 5.3 LS1 V8 swap. Motor is from a 2001 Tahoe.
  • 134K miles on the motor. Mechanic recently went through and did a mild rebuild along with new water pump, power steering pump and radiator. All new seals and gaskets throughout.
  • Rear main seal recently done along with new oil pan.
  • New Brake Pads/Shoes.
  • 4L60E Transmission. Rebuilt under previous owner.
  • All windows/locks work smoothly (installed relays)
  • 239K on the ODO.
Lift:
  • Light/Medium Kit from Cruiser Outfitters which includes:
2 - Front OME Emu Dakar Leaf Springs​
2 - Front Nitrocharger Sport Shock Absorber​
2 - Rear OME Emu Dakar Leaf Springs​
2 - Rear Nitrocharger Sport Shock Absorber​
4 - OME Poly Spring Bushing Kits​
1 - Aftermarket Greasable Front Anti-Inversion Shackle Kit​
1 - Aftermarket Greasable Rear Anti-Inversion Shackle Kit​
2 - Aftermarket Greasable Pin Kit​
1 - OME Steering Stabilizer​
8 - Aftermarket U-Bolts & Nuts​
1 - Sway Bar Extensions & Fit Kit​
1 - Hardware Fitting Kit​
Tires:
  • 5x BFG ALL TERRAIN T/A KO2 (10.50 R15)
  • Stock Wheels
Exterior:
  • ARB Bumper Bar
  • Dobinsons Rear Bumper
  • LED Driving Lights
  • Trail Tailor Front/Rear Pillar Vents
  • Trail Tailor Rock Sliders
  • New OEM Euro Mirrors
Interior
  • Original seats have been thoroughly cleaned and still show really well
  • New Carpet along with Lizard Skin/BoomMat treatment (thank you @AJR)
  • New Driver/Passenger Front/Rear Windows with Ceramic Tint
  • New Weather Stripping
  • New Windshield/Gasket
  • New Dash Pad
  • Alpine ILX-W650 with KTA-450 Amp
  • Phoenix Gold Component Speakers
Misc/Other
  • Dakota Digital Cruise Control (works pretty well for an aftermarket kit)
Now, I know what you're thinking. You're rubbing eyes and they're making that err-eah err-eah noise because you can't believe what you're witnessing. There is a few issues with the truck but they're all cosmetic:
  • The truck needs a paint job. Various work that has been done to the car makes it's so the paint doesn't match 100%. It still shows really well but when you get up close, it needs work.
  • @AJR (thank you, again) did a TON of rust repair/body work on the truck (floor panels, rear cargo windows and more) and i'm not aware of anything further on the body... but there is still some more rust work that needs to be done. The driver side door has some rust on the bottom right.
  • Headliner needs replaced... no major rips, it's just dirty.
Pictures can be found here:
Asking 35K
This is a really sweet 62, your description doesn't do it justice. I hate to see it for sale, someone is going to get an awesome deal. If anyone reading this is looking for a rig like this, you need to see it.
Was this not fixed by the member who did the rust repair because you guys ran out of steam? Or is it too hard to fix? Or did it pop up since the other rust was repaired?
Also what does
mild rebuild
On the engine mean?
Thanks
Also what does
On the engine mean?
Thanks
door rust hasn't been taken care mainly just money and time. @AJR was a kind soul and just redid my back hatch. only thing that needs to be done at this point is the door.
mild rebuild might be the wrong wording but head gasket replaced along with head bolts, lifters, lifter trays and associated parts. the LS had the original graphite head gasket on it and was replaced with MLS
