Like most projects with these trucks, you start out with some simple intention, and it ends up snowballing into an entire ordeal that takes way longer and costs way more than you intend. Such is the case with this scenario....
Since I couldn't find anything that compiled all of the required parts / part numbers/ and components to do such a thing, I decided to document this project here on Mud for others as a pseudo-instructional document.
Background:
I have been a member of this forum for a while, but haven't posted anything in the past two years or so because we recently had a baby girl and moved into a new house, so needless to say dad's 4runner project truck /tinker toy got moved into the garage and to the back burner.
However, during that time I was determined to maintain the truck by regularly starting it and moving it around to keep everything in working order, especially since i had just rebuilt the engine, transmission, and rear-end.
So, this snowball story starts with me going out to the garage after cutting the grass to move the truck out of the garage. get in. crank....wont start....crank some more....wont start.....I hear the battery going weak, so i put it on charge. came back later....crank...still wont start..
At this point I am frustrated because it had only been a week or so since i started the truck last. So I break out the FSM and start diagnosing. After a few minutes of testing I find out the fuel pump isn't pumping.
I figured that the pump might be clogged up with bad gas since the truck had been doing more sitting than driving. So i pulled the inspection plate under the rear passenger seat and pulled out the pump and found this.....yummy...
LESSON1: ALWAYS STORE A VEHICLE WITH A FULL TANK OF GAS. OTHERWISE CONDENSATION ABOVE THE FUEL LINE WILL CAUSE RUST. ESPECIALLY WITH ETHANOL GAS THESE DAYS...
so i just created my snowball. and the following posts will document how I rolled it up....
Background:
