For Sale 1986 FJ60 in Montana
Grrrrrrrr. I don't want to do this but times are tough. Here's the quick low-down on my rig. This has been a Montana truck it's whole life and is currently located in Bozeman, Montana. I know both previous owners. Since I purchased it last September (maybe October) I've put maybe a few thousand miles on it and the ODO is now reading 186k.
I don't have my receipts with me right now so I'm trying to remember everything I've done to it off the top of my head, I'll update if I missed something.
5 new BFG 33x10.5x15 A/T tires with new 8 spoke Pro-Comp wheels. Each wheel is backed with a 1/4" spacer due to the 4" backspacing. The original wheels are included in the sale as well. I did paint one of the originals white to match the Pro-Comps when I put the new rubber on.
New HFS 2 1/2" suspension. The leafs were purchased lightly used from a fellow MUD member, everything else concerning the suspension is new from HFS with the exception of the shackles, I kept the stock shackles because I wanted the smallest lift possible.
Tons of work has been done under the hood, all by a professional Toyota Master Mechanic since 1977 (Miles Toyota, see mechanics by state in the 60 section). New radiator, new hoses, new water pump & gasket, new belts, new fan, new oil sender, new fuel filter, new oil pan & gasket, new block heater, new A/C radiator (whatever it's called), A/C was also bled and re-charged, and tons more. He tested the cylinders; they were all between 150-145, which is very good. He also overhauled the Carb, it's running fantastic! My entire bill was 2 pages long, I'll need to dig it up to get the whole list.
I've also replaced the carb cooling fan with a new-to-me fan from a donor 60 (works much better than my old one). The ground wire needs to be fixed though. Sometimes, but not always, the fan with come on and off randomly. I replaced the circuit, it helped but I think the root is the ground.
Replaced the exhaust system from the CAT through the tail pipe. She has a Flowmaster now.
Added the Yakima rack.
New front bumper.
Painted the hood and front-end. The hood is also from a donor 60, the original hood is included in the sale.
Again, I'm sure there's more that I can't think of right now & will update.
Here's some pics. If you want detailed pics of anything in particular just let me know.
There's a lot of 'good' to this vehicle. I.E. The interior is in awesome condition, the rear tailgate is not rusted out, original paint still looks good (need a wax job though), all electrical components work. I could go on and on so just ask me if you are interested in any particular aspect.
I'll list the bad though. There is an exhaust leak at the manifold somewhere. The rear wheel wells have the typical Cruiser rust. As mentioned before, the Carb Fan ground wire needs to be sorted out. Windshield is cracked. Driver door was hit at some point in it’s life, the fix job was amateur and is starting to show signs of rust under the Bondo. Galley plug should be addressed. That's all the 'bad' I can think of.
Gotta get $5,750 or OBO for my 60.
Thanks for looking guys.
Oh yeah, it comes with a box of goodies too. Extra belts, grill, headlight surrounds, the old bumper, gutter trim, vents, a set of emblems, extra original tool kit, etc.
Swallowing my pride - NEW PRICE $5,750
This is a geat rig! Now that all the maintanence is done the engine is super tight and doesn't drip/leak anything (seriously, there's not a spot on my driveway) or burn oil. Always runs at 1/3 on the temp guage, amps are steady at 14, and the oil pressure is always perfect. Miles down at Miles Toyota is the man.
Open for discussion............
dude you are trippin, that price is way outta line, im in montana, i have owned alot of fjs, you are high,
if you don't have anything positive to say....
Bump for a nice looking cruiser. My favorite color if you were closer I would think of getting another one. Good luck
You're way out of line. Not cool at all.
No worries man, he's entitled to his opinion, which is easy to make without actually seeing the vehicle. But IMO it's not a way out of line price as I do have interested parties via other web sites.
off topic.....where in MT are you?.....back to main topic
I'm in Bozeman.
