- Year
- 1985
- Vehicle Model
- 60 Series
- Mileage
- 270000
- Color
- rgb(97, 97, 97)
For Sale:
1984 Toyota Land Cruiser HJ60 High Roof
Price: $48,000
Mileage: ~270k KM
This 1985 Toyota Land Cruiser HJ60 is a left-hand-drive high-roof example that was imported from Nicaragua to the US under previous ownership and acquired by the seller in February 2018. The truck was sold on BaT in July 2020 and acquired by the seller later that year. The truck is finished in gray with multi-color graphics over patterned cloth and is powered by a 4.0-liter diesel inline-six mated with an H55 five-speed manual transmission and a dual-range transfer case. Equipment includes 16″ steel wheels, chrome bumpers, sliding cargo-area windows, LED headlights, air conditioning, folding cargo-area jump seats, and a Blaupunkt head unit. This HJ60 is now offered with refurbishment receipts and a clean California title in the seller’s name.
Subsequent work under current ownership included a rebuild of the 4.0-liter 2H diesel inline-six with new rod, main, camshaft, and thrust bearings as well as replacement pistons and gaskets. The injectors were rebuilt, and the battery, alternator, vacuum pump, and starter were replaced. The clutch was replaced in July 2021, and the transfer case was resealed. An oil change was performed in April 2022.
The high-roof body is finished in gray with tri-colored decals rimmed in black. Exterior features include LED headlights, a new front bumper, black bumper caps, headlight grilles, H4 headlamps, sideview mirrors, emblems, turn signal lenses, taillamps, mud flaps, and a split tailgate. A ceramic coating was applied to the exterior in April 2021. There are scratches and dents around the body in addition to a dent in the rear bumper.
Gray-painted 16″ steel wheels are mounted with BFGoodrich Mud-Terrain KM3 tires. Aisin manually locking hubs are fitted on the front axle. The suspension was refreshed with extended-length shackles, replacement leaf springs, Old Man Emu shocks, and an Old Man Emu steering stabilizer in 2021. Braking is handled by four-wheel discs, and the front axle was rebuilt in March 2021. The steering knuckles were rebuilt in January 2020.
The cabin is upholstered in striped cloth and gray vinyl over all three rows of seating, including the folding jump seats in the rear cargo area. Staining is pictured on the front seat cushions. Work performed since 2018 included replacement of the windshield, carpets, various interior trim pieces, and installation of a dash cap. Additional interior updates include a Blaupunkt head unit, LED lighting, and replacement shoulder belts.
Instrumentation includes a 160-km/h speedometer, a tachometer, and gauges for coolant temperature, oil pressure, voltage, and fuel level. The tachometer was replaced in 2021. The six-digit odometer shows 265k kilometers (~165k miles), approximately 3k of which were added under current ownership.
Amenities consist of factory air conditioning, a 12-volt outlet, push-button four-wheel drive, and an AM/FM radio.
Power is sent to the rear or all four wheels through an H55 five-speed manual transmission and a dual-range transfer case.
Recent service and repairs include a vehicle safety check, brake service and flush, replacement of the intake tube, fabrication and repair of the rear sway bar, centering of the steering wheel, greasing and checking all fittings, complete oil service, diagnosis of no-start and fuel issues, replacement of the EDIC, and repair of miscellaneous wiring damaged by rodents. The brake master cylinder is recommended for future replacement.
Further parts and services added include a brake flush kit, oil service kit, miscellaneous shop consumables and hardware, an EDIC control module with associated parts, miscellaneous electrical and wiring components, an oil pressure switch, sway bar link hardware, an air intake hose, and testing fuel.
In February 2024 parts added included a brake flush kit, oil service kit, miscellaneous shop consumables and hardware, an EDIC control module with associated parts, miscellaneous electrical and wiring components, an oil pressure switch, sway bar link hardware, and an air intake hose.
Additional work involved the fabrication of parking brake brackets, welding, parking brake configuration and equalizer install, and replacement of fuel and service fluids. An OEM Toyota shoulder belt kit, tach signal sender, and new tachometer were also installed.
Warranty-related tasks included checking HAC effect on fuel mixture, exhaust adjustments, tachometer installation and adjustments, steering wheel centering, topping off engine oil, re-securing fuel door release handle, and greasing relay rod ends.
Earlier mechanical work included fabrication of parking brake brackets, welding, parking brake configuration and equalizer install, replacement of fuel and service fluids, installation of a tach signal sender and new tachometer, and various warranty-related tasks. This included checking the HAC effect on fuel mixture, exhaust adjustments, tachometer installation and adjustments, steering wheel centering, topping off engine oil, re-securing the fuel door release handle, and greasing relay rod ends.
This HJ60 also received a disc brake conversion kit, an OEM Toyota shoulder belt kit, and a new tachometer with a signal sender. Comprehensive front-end rebuild services included front hub and axle reconstruction, resurfacing knuckle swivel ball ends on the differential housing, assembling knuckles, and installing inner seals and locking hubs.
Mechanical services also involved front differential breather installation, disc brake installation with stainless steel flexible brake lines, brake hard line routing, and bleeding the brakes. Further updates included the fabrication and installation of a parking brake system, final mechanical services such as exhaust fabrication, steering column u-joint replacement, differential service, front hub reconstruction, sway bar end link fabrication and installation, wiper motor reconstruction, air intake tube repair, gas door lever repair, and clutch master cylinder adjustment and service.
Lastly, detailed work included full color correction and a high-gloss ceramic coat application, trim black polish and restoration, and complete paint and body ceramic coating, including wheels, tires, and glass.
Price: $48,000
Mileage: ~270k KM
