Rear sway bar frame brackets? Thanks
Its solid, a little surface rust. The holes where the emblems were have been filled. PM me a phone number or an email address and I will send you some pictures.How's the tailgate?
Everything you asked for has been spoken for. The smog pump and alternator brackets are taken. Anything else engine wise is still available.Are you willing to sell parts off the engine or just the whole engine assembly?
Example:
Lower thermostat housing, distributor, igniter etc.
Ill get under it and take a look tonight. Ill take some pics and let you know.Rear sway bar frame brackets? Thanks
Yes, I have all those parts. I'll get them apart here in the next few days and shoot you some pics.Is the oil cooler and oil filter housing available? I'd also be interested in the oil cooler pipe (hard line) from the front of the oil cooler to the water pump.
OK. I'm on it.Pic of the AC bezel too please.
I'll take a look.Is the Hot Air Intake heat shield covering the front of the intake manifold available or not a crumbling mess?
How about the upper thermostat housing as well?Yes, I have all those parts. I'll get them apart here in the next few days and shoot you some pics.
thermostat housing spoken forHow about the upper thermostat housing as well?
There does not seem to be any rear sway bar.Rear sway bar frame brackets? Thanks
Yes, the dome light housing is there and in good shape, but the lens is cracked.
I should have the choke and cable, the carb insulating plate and the carb fan. The air inlet hose is there, but taped up with electrical tape, but its your if you want it. The distributor bracket is going with the distributor to a buddy of mine.Seeking choke and cable, air inlet hose (from fender wall), distributor brackets with bolts, carburetor insulator plate and the carb cooling fan. I am fine with above pics.
How much for the dome light and shipping to 99021Yes, the dome light housing is there and in good shape, but the lens is cracked.
