WEBER CARB SURGES LOW GEAR IDLEING HELP
SORRY FOR THE YELLING. I have replaced all fuel lines. Adjusted weber carb. Adjusted timing. It has a estimation at idle went in neutral and give it gas.WHY ARE YOU YELLING? PLEASE INCLUDE MORE INFORMATION. WHAT HAVE YOU TRIED ALREADY?
Down the road at 50 mph it seems ok but if your idling in a low gear it surges. I have replaced fuel pump ..
Its 1983 fj60 2fWHY ARE YOU YELLING? PLEASE INCLUDE MORE INFORMATION. WHAT HAVE YOU TRIED ALREADY?
If the problem started when the Weber was installed- then that’s the problem- that carbThe smog has been taken off and new gas lines. It idles ok but surges when at low speed in low gear. Any ideas. Put weber carb on when all the trouble began.
