For Sale 1981 FJ40 Tub, Drivetrain and Brake System
North Alabama
I have a complete drivetrain (motor would have to be rebuilt but everything else works perfect) brakes still worked when I rolled it off the trailer. It has been wrecked and will require a couple of hundred dollars on a frame machine to pull it back completely square. It has no title. As you can see from the link below, there is practically no rust. It is the best original unmolested tubs I have ever seen or heard of, not to mention all the other parts it has. Picasa Web Albums - Jonathan - 1981 fj40 rep...
Would rather sale as a whole unit for $4000, although I would sell major systems as a lot such as front and rear axles, brake system, motor/trans/tranfer, tub, etc.
call at 256.654.1315, pm or email.
I need the drivers side inner door hinge off that tub if it has good rubber. I don't know if the hinges are handed, I think they are, but upper or lower should be the same on each side. Let me know if you are willing to part with 1.
interested in steering wheel
Interested in rear axle w/complete parking brake hardware, gearbox crossmember( I think I'm 2nd in line on this), and crank pulley from 2f.
I have been asking $2800 for the tub.
Transmission support cross member is $100 including shipping.
rear axle complete with parking brake hardware is $400 plus shipping.
crank pulley is $150 including shipping.
stock steering wheel $75 including shipping.
I don't have the door hinge part.
These are asking prices. If you are interested make me an offer. I have to start somewhere with the prices. You can call me at 256.654.1315 to discuss.
Complete front axle with working disk brakes is $700 plus shipping.
I assume you just want both complete axles. If that's correct I'll take $900 plus shipping.
If you want the complete brake system, booster, master cylinder, brake lines, brake pedal, etc it will be another $700.
All brake system parts are in excellent working condition.
Yikes! I know these are "asking" prices, but did you just pull them off of the SOR price list?
good luck
