Wanted 1967 FJ 40 Rocker Shaft Assembly (1 Viewer)
Montana
  1. 40 Series
Refreshing original F engine and need to replace the rocker shaft assembly.
Thanks
1967 is a transitional year, so a little more information is required. Are you working with a F135 or an F145 engine?
I have both types readily available. www.marksoffroad.net
Perhaps you can tell me?
You can also run a 2F rocker arm assembly on an F145, but requires drilling and tapping a rocker tower and flipping the rocker arm tube. It worked well for me.
F145. I have about a dozen of those, all boxed. Give me a jingle on Monday and I’ll get you a shipping quote.😊
With the brass tag stamped T-67 and by the VIN this appears to be a June 1966 build date. That would definitely have been a F135 from the factory. By the intake manifold made for and two barrel carburetor and one barrel carburetor with adapter would make the a 9/67-3/69 F145 engine.
