14BT and a GTurbo (2 Viewers)
Down Under
As the title says, has anyone put a GTurbo on a 14BT?
Pretty certain @Hulsty had one on a 13BT
yup on my 13bt
Awesome, how much of a difference has it made? What PSI are you running? Is there a significant difference in turbo spooling at lower RPM? Any issues since installing? Any feedback greatly appreciated.
Cheers
Are you running an intercooler? No issues running 25 PSI? I'll be rebuilding my 14BT in a couple of weeks and I'm considering upgrading to the green GTurbo after that.
Yeah I run a PWR barrel, takes 80c out of EGT's. Only issue is it gets warm after extended periods holding it flat, ie 5min at say 2800rpm, 25psi the gauge is creeping up. Stock radiator with 1HDFTE clutch and fan. Cooling system is borderline to small. Not a normal situation so I dont worry about it.
If you can fit a HDJ79 radiator it would help, they are taller.
