Probably seems like an easy question but I'm installing an aftermarket water temp cause the factory one sucks. Where is everyone installing them at?
coolant where?Anything better for coolant....
at what part of the engine?Just the overall engine coolant temp
consider installing the new temp sensor in the coolant loop at the lower left side back of the block where the coolant exits the block to feed the heater circuit. This loop flows coolant all the time. That's where I tee'd into the coolant circuit to feed the FPHE that heats the fuel mix I burn.
That location next to the existing temperature sensor only reads coolant temp in the radiator circuit and will only read block temperature if the tstat is fully open when the engine is close to overheating.
You can also locate the sensor in the coolant circuit tube that cools the turbo
OEM and my aftermarket port are on the lower part of the housing which is below the t-stat, yes? Your OEM sensor is on the upper portion of the housing?
