So I finally got the 13BT glow timer and spent the morning trying to get it to function. I was able to get the pre-glow to function as designed, but I still haven't been able to get the post glow to work. Per the above diagram I have not been able to get power to pin 5 which would run the secondary post glow relay. I have pin 10 grounded which by-passes the temp. sensor, pin 7 is not hooked up to anything, pin 1 is not hooked up since it looks like it only makes a 12v connection after the pre-glow for only a few seconds, pin 11 is what runs the pre-glow, pin 3 is wired from the battery through a 12v indicator light, pin 4 is wired directly to the battery, pin 6 is hooked up on the pre-glow line, but seems to work as expected, but I might try to combine with the post glow coil to see if that makes a difference, and pin 9 is the questionable one. If I run pin 9 on ground, which I believe it should be by looking at the wiring diagram, it stops pin 11 from getting 12v which stops pre-glow. This makes sense to me because once you turn your switch to start and back to IG the timer would think it would need to pre-glow again, and this stops that sequence. Anyway, any ideas would be greatly appreciated.
Thanks
Scott
