13BT Fuel Filter Return Hose
Does anyone know of a Solution to a Leaking Fuel return line from the Fuel Filter? Mine has a leak . It's the line that has Banjo Fittings and a rubber hose crimped in middle. Don't want to get a used one as the new Diesel is hard on soft lines. I will remove and see if a hydraulic place local can make one or fix mine. ?
Post a pic, Cohner.
Any decent hydraulic shop should be able to make that.
I had a shop make my alternator/vac pump oil supply. Same idea. Bring them your ends and they can reuse.
Black soft line in pic. Going to go to a hydronic hose shop tomorrow hopefully and see if they can make a new one or fix my oem banjos with new hose
ya, i need one of them for my 3b too....
