I just installed a new AC pump, expansion valve, replaced ALL the Orings and Serviced my AC, I got the air temp down to 45dg, now my issue is air flow, on hi the blower seems to be bit weak. I've replaced the blower resistor and all four speeds work, it just seems a bit weak on the high speed, thinking the blower motor is the logical thing to replace. I have had the ENTIRE heating and AC system apart so I know the evap and heater core are clear of foreign matter, I also re sealed the system. Has anyone had these issues before, has a new blower motor fixed the problem?
Torched, worn, or gone motor contacts too, there's a recent thread IIRC on the board somewhere. Also turn it on and carefully reach under the dash and see if any of the weatherstrip has worn off the duct fittings and is letting all that air conveniently cool your wires and dash structure for ya from all the air escaping the intended path.
