12v switched source in engine bay.
Prosper, TX
Hi Everyone,
Looking for some advice. Need a 12v switched source in the engine bay of a LX570, ideally on the left hand side when looking at engine bay (filter box side). I know I can run a fuse tap from box, but then I have to snake it around, and don't want to have the cable coming out of fuse box etc.
Don't need any amps just to trigger a device to on.
Or do the majority of you just tap a fuse in the cabin a run a cable through firewall?
Thanks!
Sorry, don't know of anything over there to use for switched power. But maybe you could move your relay to the fuse box side? I don't know what you are powering, but since you don't need amperage, I assume a relay. This would keep you from having to run your signal wire across too.
