Hey guy's, I've put this in the 70 series section and I think I might have some more luck here so just a repost trying to get an answer
Hey folks, I've decided to install a "Wilson" switch into my 12v Australian hj75. I'm having starting difficulties and have done some test's, and I believe the timer is the issue. (especially after reading how so many people have issues with the timers and super glow systems)
Now from what I can understand. I'll need a set of 10.5v glow plugs.
Also I won't be using a controller so I'm just going to run power to a push button on the dash, to control a relay which will be sending 12v to the busbar.
From what I have read so far on various thread's this is all I need to do.
Now instead of mixing with the exisiting wiring I'm going to be using new. So am I able to simply remove everything connected to the busbar and run my 12v straight to the busbar therefore being the only thing connected to the glow plugs?
Some of this may not make sense as it's rather late
But my main question is simple. Can i remove everything and simply run 12v to the plug's in order for them to operate.
Thanks guys please excuse my ignorance!
This is how my current system looks exactly, (ignore all the part numbers)
Can I simply remove the green in order to isolate the plugs and just keep all the original wiring intact
And then add in what I have drawn up
Also the red 12v line in the first picture is what I intend on running from the relay like you see in pic number 2.
