120v Plug / Uses? (3 Viewers)
Will the rear 120VAC outlet power and ARB or Dometic fridge? Have a road trip this weekend and I don't have time to install a dedicated 12v socket in back.
I think that's in the range of you will just have to test it. My outlet seems to trip before 100w and won't run my IceCo fridge (with a cheap chinese laptop style brick doing AC/DC conversion). The nicer ARB/Dometic may be more efficient.
The rear outlet powers my Indel B 50L with no problems. Gives my aux battery a break and only get used once i get to my destination. As @lx200inAR said you'll have to check
Can confirm Waeco CF-110 set at full freeze and turbo setting will run without causing the 120v outlet to overload on a 2021...at least for the 20 minutes I ran it. Once it reaches the desired temp, it will cycle every few minutes, so the initial cool down should be the test. Will run it for 12 hours this weekend and we'll see how it holds up.
Anyone tried putting a USB or USB-C strip next to the outlet? I am guessing an easy splice, cut the plastic and add some body mount screws. I am thinking of have ng my magnetic o-lights stored and charged in the back.
It powers my Iceco VL45 with no problem. I also charge various batteries such as power tools as well as a lifepo4 power station with a laptop usb-c charger and it goes right up to 100 watts without tripping. The power station I have is limited to 100 watts so there may be room to go above. I have a 2013 LX. You can also run a dc extension cord from the backseat 12v outlet to the rear. I’ve done that once or twice.
I have use it to power my Dometic CFX95 once it is at temp. I’ve switched to using a Lion Safari ME (1kw, 3k inverter) then worst case if there is no sun for days using the 110 to charge it.
Here is my set up. While driving the battery sits next to the fridge with plenty of space.
