105 series lift
Hi,
I have bought the fitted the 50mm terrain tamer coils in my 105series Landcruiser.
However, after fitting its lifted about 4-inch in the fronts and 5-inch in the rear. i had recently fitted new terrain tamers shocks as well. now after fitting the coils, i feel its bit unstable in the front and kind of shakes / floats.
What do i need to correct this? Do i have to buy the castor correction kit? what else to stabilize the ride? and what degree castor correction kit i should buy, and what will it basically do? Can anyone please explain. sorry iam new to this
Yes...exactly: You need castor correction. Different methods to get more positive caster but IMO I'd see if Slee's arms will fit...should but check with him. Done.
As you lift the front suspension caster is reduced. The more the front suspension is lifted the more caster is reduced and the more relative and corresponding caster correction is needed.
Here: http://autorepair.about.com/od/glossary/ss/df_alignment_2.htm
