100 Series Hot-Soak Hard Start / Flooding
Houston
Hey all,
I’m chasing a weird hot-soak starting issue on my 100-series (2UZ-FE, ~420k miles) and wanted to sanity-check my diagnosis before I start throwing parts at it.
Symptoms:
  • Cold starts: perfect
  • Immediate hot restarts (shut off and restart right away): perfect
  • Hot-soak restarts (30 minutes to ~2 hours after shutdown): takes 2–3 cranks to start
  • Strong fuel smell when it finally starts
  • Issue is intermittent
  • Once running, it drives normally
Recent work:
  • Injectors were ultrasonically cleaned and flow-tested ~3,500 miles ago
  • New injector O-rings installed at that time
  • Problem started only after the injector service (was not present before)
Diagnostics I’ve done:
  • Tried Toyota “clear flood” mode (pedal to the floor during cranking) during a hot-soak no-start:
    • Engine starts more easily on the second crank
    • Flares up to ~5k RPM briefly
  • No CEL or EVAP codes
  • Cold and immediate hot starts are consistently normal
Questions:
Has anyone seen injectors start leaking after cleaning on high-mileage 2UZs?
If so, did you replace one injector or end up doing the full set?
If I do replace the fuel injectors is it best to go with OEM (expensive) or can I go with cheaper options (like taking them off a car I found with 125k miles).
Thanks for any advice.
AI suggests that cleaning high mileage older injectors can reveal other underlying issues with worn injectors, solenoids, spray pattern etc. Chances are the cleaning did more harm than good.
If you haven’t changed your FPR, that’s a good thing to do if it’s OG, also if your fuel pump is original- it should be replaced- +200k miles, +20years it’s efficiency has diminished.
AI response to Injectors: YMMV (it’s AI)
“Short answer: yes, it can introduce new drivability issues — but not because cleaning is harmful. It’s usually because the injectors were already worn, and cleaning exposes the underlying problems.
Here’s the clearer breakdown.
Why cleaning high‑mileage injectors sometimes causes new issues
1. Cleaning removes deposits that were “masking” wear
On very old injectors, carbon and varnish buildup can actually seal tiny internal leaks or compensate for worn pintles.
When cleaning removes that buildup, the injector may start:
• Dribbling fuel
• Having poor spray pattern
• Flowing unevenly
• Sticking intermittently
So the engine may run worse afterward — not because of the cleaning, but because the injector was already failing.
2. Weak injectors may fail completely after cleaning
High-mileage injectors sometimes have:
• Weak internal springs
• Worn pintle caps
• Cracked plastic bodies
• Failing solenoids
A cleaning machine can stress them enough that they stop working reliably.
3. Cleaning can reveal other engine issues
If the engine was running rich/lean due to dirty injectors, the ECU may have adapted over time.
Once injectors are cleaned and flow correctly, the engine may suddenly show:
• Vacuum leaks
• Weak ignition components
• Bad O₂ sensors
• Low fuel pressure
These issues were always there — they just weren’t obvious until fueling was corrected.
4. Poor-quality cleaning methods can cause problems
This is less common, but possible:
• Harsh chemicals damaging seals
• Improper ultrasonic cleaning cracking plastic tips
• On-car cleaning pushing debris into injector screens
A proper shop with the right equipment avoids this.
When cleaning helps vs. when replacement is smarter
Injector Condition Cleaning Helps Replacement Recommended
Mild deposits, normal wear ✔️
Uneven flow but no mechanical damage ✔️
Very high mileage (150k–250k+) Maybe ✔️ Often
Cracked pintle caps or leaking bodies ✔️
Weak or failing solenoids ✔️
Engine misfires that return after cleaning ✔️
AI Summary-
Cleaning is a good first step, but high‑mileage injectors are often near the end of their life. If cleaning makes things worse, it’s usually a sign the injectors were already failing internally.
If you want, tell me:
• The vehicle
• Mileage
• Symptoms before and after cleaning”
• Dribbling fuel
• Flowing unevenly
• Worn pintle caps
• Failing solenoids
• Vacuum leaks
• Bad O₂ sensors
• Low fuel pressure
AI Summary-
• The vehicle
• Mileage
• Dribbling fuel
• Flowing unevenly
• Worn pintle caps
• Failing solenoids
• Vacuum leaks
• Bad O₂ sensors
• Low fuel pressure
AI Summary-
• The vehicle
• Mileage
Hey all,
Symptoms:
Recent work:
Questions:
Ok, so this situation has been resolved. What finally fixed the problem is replacing the fuel pump since the issue was the fuel pump check value failure. For those that have the hot start problem the steps seem to be: 1) check the radiator temperature regulator, 2) check the fuel pressure regulator, 3) check the fuel pump check value, and then the fuel injectors.
On fuel injectors, let me reinforce "Chuck" at Fuel Injector Specialists in Wheat Ridge, CO. He was great. Knowledgable, fair to a fault, and pretty quick. He was super helpful. That was not the problem in the car, but now I have 8 working fuel injectors with a good spray pattern.
Happy to hear, issue solved.
I'm curious; What year is your 100 series?
