(If the 100 even has bump stops...)
Look on the frame right above your rear axle. It will have a metal base, bolted to the frame, and a black rubber stop.
Thank you, I did not find in the front, only lower stops in front. But while adjusting the front torsion bars it has been adviced to maintain 1 thumb thickness on the upper bump stops and this is what has stumped me.
You have to understand that the LC100 is a new concept and TOY used bumpstops in the front that you can't see. This was done to confuse the competitors
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
