stinkyfj60 said:why do you want to swap a diesel for a petrol engine?
Cruising range would be the biggest draw to the diesel for me.
Well, you'll have to start your research that's for sure
So, here is a good laundry list of starting places,
What drivetrain do you plan to attach to the motor? Compatibility of bell housings, gear boxes, transfer case, drive shaft lengths if you change gearboxes with different lengths.
Then there will be adapting it to a dissimilar truck. New/different cross members , motor mounts, exhaust, routing for cooling and fuel, adding an electronic pump to the tank, engine ECU and all other associated electronics tied into the gas motors that the 1HZ doesn't have, steering lines, gear shifter linkage, etc, etc, etc.
It's doable and if you have some fab skills and technical prowess, would be a neat project.
Sent from my iPhone using IH8MUD
Thanks for the reply,
I thought someone here have already done engine swapping and could help me out on this,
i will talk to my mechanic and see what he can do,
regarding the electrical stuff and ecu everything will be running on motec M800, electrical and wiring stuff arent an issue only mounting the engine, gear housing and these things are what im concerned about...
