I just put 863s in the rear yesterday and i did not have to disconnect the brake lines. The rear breather did pop off though.
When replacing the rear springs, does anyone have experience on whether there is any spring tension left on the springs when you lower the axle? Can you lower the axle enough to release all the tension and not damage/break the brake lines, breather hose, or ABS lines?
When replacing the rear springs, does anyone have experience on whether there is any spring tension left on the springs when you lower the axle? Can you lower the axle enough to release all the tension and not damage/break the brake lines, breather hose, or ABS lines? .
Thinking of doing the rear suspension installation this evening. Looking at the threads and instructions, it wasn't clear to me if you lowered the axle as a complete unit (both sides descending equally at the same time or if you needed to support one side and allow the other side to lower to replace the spring (then do the opposite to replace the other side). Maybe it makes no difference, but thought I'd ask in case it does. What do you think?
I find the truck will actually shift sideways if lowering one side at a time. Maybe I'm putting the jackstands in the wrong place (I usually put them on each frame rail end near the rear crossmember, I found that putting them up near where the rear lower control arm mounts to the frame is too near the tipping point of the truck). Any othe suggestions on where to put the two jackstands? Never was an issue on my old 80s. One other question on the front suspension, does it matter if one side t-bar is indexed differently from the other, as long as there is adjustment left on both sides? Even if it takes more turns of the anchor bolt on one side versus the other (e.g. the bolt may end up sticking out further on one side), as long as it is an even lift side to side does it really matter? Just curious.
This is a good thread on installation of the OME lift. So, rather than start another one, I'll ask a question here.
All the instructions I've read seem to indicate this, but would appreciate some input based on others experience.
I'll second the post above, once you get into the front end, it's a lot easier than what I originally expected (the instructions from Slee and other posts here explain the process very well).
For step 21...
Driving the rear TB anchor arms off isn't easy and it can be a bear to get them off. I thought I'd add a visual to what worked for me to this one since it is listed in the FAQ and hopefully help out others in the future.
I took two vice grips and clamped them down right as the TB begins to bell in diameter before the splines. Lock them down with all you got with rounded jaws. This gives you the ability to beat against the "frame" and hold the Tbar in place while driving the anchor arm rearward freeing the Tbar.
Once I figured this out, I had both sides out in a matter of minutes.
Anyway I just thought I'd add to the already posted info. Thanks again to the OP.
Pic below is passenger side under the slider looking to the rear Tbar mount. You can see how I leveraged the vice grips against the frame and used the drift to drive the anchor arm free from the Tbar.
