1-HDT oil drain plug gasket part #? (1 Viewer)
Rob Faucett
GOLD Star
Seattle, WA
For a 1-HDT is the oil drain plug gasket part # 90430-12031?
Thanks fellas!
Rob
Its the same washer used on about 300-400 toyota cars ,vans and truck models,petrol or diesel. It will also be the same as many other vehicles. It doesn't need to have Toyota written all over it,just needs to be the same diameter and material.
Corolla ,Camry are the same.
Cool. Always good advice from you. Much appreciated. Enjoy your winter:)!
I just buy cork gasket and cut two donuts and call it a day... Cheap and easy and when they get hard I just cut some more.
I tried a leather gasket ,leaked a drop or 2 but ok till the next oil change when I swapped it for a proper one.I think Toyotas are copper but Ive been using aluminium which works fine.
I use the same one over and over,just flip it so it gets bent to fit in the opposite direction
Are there different sized plugs?
AFAIK all landcruiser plugs are the same ,but obviously other makes have different sized plugs. You want to get the correct one without taking the old one out?
There are actually a number of different sized LC plugs depending on series and year.
Pretty much everything went to the 12mm plug starting in about 1988-1989 time period with the corresponding 90430-12031 drain plug gasket which is made of a teflon-like material.
roscoFJ73 - Yes, trying to have everything on hand before I start
beno - Thanks Onur, wealth of knowledge!
