HandForged
Built Not Bought!
- Location
- United States
I have two engine setups for my project and it's time for one to go to make way for other parts.
1996 VW 1.9 TDI: This engine has 140k miles on it original, zero blow by and great oil pressure. It runs flawlessly and was pulled by me for my use from a running driving Passat. So it has the correct side oriented motor mounts. It is complete, top to bottom with the correct Toyota starter, intake and exhaust manifold and turbo. I will include an upgraded intake manifold if you deseire. I have extras. This engine also has a Landrover mechanical fuel pump already installed. Resealed and good to go. This pump is in stock form and can be modified (easily) to any power level you would like. This combo only needs two 12v power sources to run, no electronics of any kind. No engine management or computer. If you have been looking for an engine swap that makes good horsepower and sips diesel (28 plus MPG) this is it. You won't be able to buy the parts for what I am asking. Selling at a loss to get it out of the way and put some other parts in my shop. If you are not familiar with these engine, I can also include a factory shop manual that will tell you everything you would ever need to know broken down to the kindergarten level. REALLY EASY. Pictures are on my build thread of the engine and adapter. These are about the best that you can get. They aren't cheap plates, they are a system with all the best parts and retail over 900.00 plus shipping.
Diesel conversion specialist adapter kit: this adapts the 1.9 TDI to the Toyota R-150 or r-151 5 speed transmission. I will also include a brand new clutch, flywheel and pressure plate with this adapter.
This is the setup that I have been using in my project FJ45 for mock up. I can ship these via Fastenal at the buyers expense, which in the past has run about 340.00
2500.00 for the engine/adapter/clutch,flywheel,pressure plate with the upgraded Land rover fuel pump installed.
2900.00 shipped price to include engine being strapped to a pallet, shrink wrapped and shipped anywhere in the lower 48 states.
