Not to confused OEM and OME (old man emu). I was about to pull the trigger and get OEM Shocks from Toyota (all four corners)
and 1.5" Rear spring from OME2865 and OME standard 30.4mm OME303001 torsion bar
Just before I pulled the trigger a friend texted me said that if I use OEM Toyota shocks there will be not enough travel? and I have to use limit strap? is that correct?
Thank you
Thank you
