LC finally back on the road (HG failure)
LINUS
Waiting for the Great Pumpkin
PNW - WA
After blowing my HG last March (yeah - it's been a while!) my LC is finally back on the road! Mine was the standard #6 chamber to cooling jacket for those of you keeping score at home.
1st off - A big "THANK YOU" to C-Dan for all the help with parts and advice on what else to change while in there (I have 130k on my odometer)
A few random things from my fix :
If you have a FSM and some patience this motor is a snap to work on. Everything seemed to be indexed so it was impossible to place a rotating part in out of alignment. I really like this motor for service-ability. Nothing like the VR6 motor in my old VW's - thank God.
I don't know about some of you, but I couldn't undo my wiring harness to get it through the intake runners - either I couldn't find the plugs visually or my paws were just too big to get on them. I used a Sawzall and cut my intake between the 2 runners where the offending metal was. I just spaced the intake from the head on the 2 outboard studs with some 1/4" plywood shims and ran in 2 bolts close to my cut area with shims there too and 2 cuts later out came my lower intake. I radiused the cuts afterwards and reinstalled just like that. You don't lose any mount points and the harness slides out fine.
For the record I had the shop who had the head do a valve grind, shim the valves, and they removed between .003 - .005 from everywhere on the head aside from the #6 area. The #6 area on my head was a slight low spot so that was the reason the head got milled at all. I didn't overheat the truck when I blew the gasket, so I had a real mild problem compared to others out here. I was on it the minute things seemed odd so there was no added damage (warped head stuff) aside from the gasket needing a change-out.
Thanks Rick & Lars (I was reading some of your posts as I was doing mine as referance) , and again thanks to Dan - you guys made it easier for me to do mine.
Now I just gotta get those lockers in and do full axle services.
Great solution to the wiring harness issue and I'm glad you got through this OK. You can update your sig line now. :D
-B-
(..... just waitin' for the inevitable slurs involving someone's beloved mother.... ) :rolleyes:
-B-
-B-
I don't know B, Junk is getting kinda mellow these days (see sealer thread....)
E
big worm said:
just out of curiosity, how did your head gasket get blown?
Unfortunately it is a common problem with the 1FZ, the original gasket has a higher than normal failure rate (for Toyota), the new redesigned head gasket has been trouble free so far
-B-
Duely noted B - thanks - never felt so good to change that sig line!
Raven hit it on the head (no pun) - my gasket was original since all the bolt paintmarks were still factory, so 130k seemed like the upper end of the curve that us 1FZ guys get before needing a HG changeout since they just go bad at some point - factory flaw.
Anybody else have a hard time with the wiring harness?
I'm going to leave the blown head comment for J - his field of expertise :D
