- Joined
- Sep 28, 2002
- Threads
- 558
- Messages
- 8,122
- Location
- Kamloops, BC Canada
- Website
- www.shopraddcruisers.ca
We are way behind with the 1982 FJ40 from New York but its finally done (140 hours into the body after welding and it looks real sweet).
Anyways looking for all your professional input.
Hoping to turn this around in record time as we have another truck needing to be finsihed ASAP.
So far its looking real good, we are pulling the body off the mustard cruiser on our web page and changing it back to Tan(the original colour LOL).
Anyhow we are only two days into the project and things are going great, body almost completely dissassembled, most parts in the paint booth today.
We are looking for ideas on Starting and charging system. We have thought about the 24 volt start and the 12 volt run system, we would only need a 12volts start (Hint Hint Beanz just joking) Prolly buy a new starter from Enz as suggested by Sheldon.
Power steering, go with 60 series box or try and fit the engine with the mini truck PS box and booty fabbed mount. The box is much smaller than the original manuel unit and it may fit?
Were gonna use a manual switch for the glow plugs with a timer, we even had thought about keying into the ignition and having a light on the dash? I like the old BJ40s with the little element in dash that glows red showing you when the plugs are ready, that was a way cool and simple system.
Fuel tank, thinking maybe under the bed were the muffler is and running the filler neck through the tub at the back and under to keep a factorylook.The exhaust will come out the other side and will have to think a little on that.
Kinda sad but the factory seats which were repholstered will be pulled along with the sandblasted seat frames in order to install buckets. We are going to bend up some tube and make our own brackets. Thinking Toyota Celica? Supra? Honda Prelude? just not sure but I know they must be a very thin base so that puts the Supra seats out of the running.
Not very tech but I found a square Bezel and square steering wheel that would look kinda trick in this rig? Just pop on a Diesel emblem on the grill and we would have some people scratching thier heads.
I will post more tomorrow as I am beat from sanding panels all day.
Thanks in advance........
