bjowett
Supporting Vendor
Here is a veeeeeerrrryyyyy simple 2" drop for the rear shock brackets. The blocks are a basic Nylon plastic spacer that I had kicking around. They are for limiting compression travel on some of the Koni dampers I use.... obviously they work great in the other direction. 4 (2 per side) M10 or 12(???) bolts that are 2" longer than stock hold it all in place...
These would be an easy fab project using some round steel tube of the required length.
