2 questions here I am hoping you can answer !
Number 1 - occasionally ( on cold days ) when I first start the truck and put it in reverse, everything is fine. When I shift to D after I have backed the truck out of the drive, it will barely move. Drop it in low, it moves, and then afterwards put it back in D and no more problems.
I have only noticed this on the first start up - it does not seem to do this afterwards- ?
Fluid appears to be clean, and at the proper level. No shifting problems, no silpping, no other symptoms so far as I can tell.
Number 2 -
While searching
, I came across a thread that said you should not pull in reverse - like when you are pulling someone out.
I am confused there as on all the American 4 X's the general knowledge ( or general disinformation if that's the case
) was that reverse is a lower ratio and so therefore gives you more 'oomph'.
( I love technical terms !
Plus, the 4 X Suburbans I had had tow hooks factory mounted on the front frame rails which made it even easier to hook up for a reverse pull.
Never had any tranny issues caused by doing that, either.
Why would the LC be any different there ?
Thanks for the education !
Britt
Number 2 -
While searching
, I came across a thread that said you should not pull in reverse - like when you are pulling someone out.I am confused there as on all the American 4 X's the general knowledge ( or general disinformation if that's the case
)Plus, the 4 X Suburbans I had had tow hooks factory mounted on the front frame rails which made it even easier to hook up for a reverse pull.
Britt
