Which fuse where?Fuse checked ok.
Mine was doing the exact same thing as the op. I discovered that on the underside of the switch there is a tiny plastic part that actually pressing the button and mine was broken off. I bought a used console off eBay and hooked it up and it worked like a charm. Unfortunately the button isn’t sold by itself. That’s a very flimsy little piece of plastic for such an important job
Glad and sad to know im not the only one who went through that wtf’ery. Worst part is I took it to Lexus who determined that i needed a whole new 4wd ecu. Luckily I didnt have the money for that at the time or I would have paid them to do absolutely nothing to fix the problem.Happened to me too!
LCDC 2022 retrospective from a first-timer
I'm almost home from my first LCDC and wanted to write down a few things before I forget—and mainly to forget how crummy this hotel room is in Twin Falls. Gratitude First and foremost, thank you to @codyaustin5, @indycole and the cast behind the scenes, and Dissent, Slee, @Eric Sarjeant and...forum.ih8mud.com
I took mine all apart and cleaned it, but still not fixed. I’ve switched the plastic plunger for one from a different switch since I am no longer using my AHC. It was ridiculously dirty, and that plunger was gummed up with coffee or Cola. I will pull it out again and see if I can close the contact manually to engage for lowMine was doing the exact same thing as the op. I discovered that on the underside of the switch there is a tiny plastic part that actually pressing the button and mine was broken off. I bought a used console off eBay and hooked it up and it worked like a charm. Unfortunately the button isn’t sold by itself. That’s a very flimsy little piece of plastic for such an important job
I think the one for 4 lo is the only one that has that little tab on it. I’m pretty sure you have to pus that button down before you can switch to 4 lo so if you can move it freely it’s not really engaging.I took mine all apart and cleaned it, but still not fixed. I’ve switched the plastic plunger for one from a different switch since I am no longer using my AHC. It was ridiculously dirty, and that plunger was gummed up with coffee or Cola. I will pull it out again and see if I can close the contact manually to engage for low
Did you ever find a solution to this? I took my switch panel apart, cleaned it all up, but it did not help. I can manually actuate the different switches using a connector to bridge the switch gap on the pcboard, but nothing on the 4 low. I was wondering if anybody has seen a wiring diagram so I could try manually engaging for a load from the wiring connector instead of the PC boardI haven't seen any posts which day the 4 lo light didn't even come on.. I had been engaging 4 lo a few times a month for the past several months and while it did take time to engage it always did. Please note I am getting no 4 lo light at all and don't hear the relay clicking (used to click when it engaged) clicking was from pass side dash area. Just thought I would add that info if that triggers any responses.
If by little tab, you mean having to push the switch down before you can switch it to four low, I did not need to change that part of the switch. Just a little white plunger that pushes down on the contact. I have since taking the part again, and tried to manually bridge that connection, and nothing shows up on the dash, and definitely no clicking of the actuator. Does anyone know if there is a specific fuse for this?I think the one for 4 lo is the only one that has that little tab on it. I’m pretty sure you have to pus that button down before you can switch to 4 lo so if you can move it freely it’s not really engaging.
If by little tab, you mean having to push the switch down before you can switch it to pour low, I did not need to change that part of the switch. Just a little white plunger that pushes down on the contact. I have since taking the part again, and tried to manually bridge that connection, and nothing shows up on the dash, and definitely no clicking of the actuator. Does anyone know if there is a specific fuse for this?
I would like to try manually bridging the wires on the connector, if I knew what wires to bridge. I don’t want to short something else out.
I tried shorting there connector, but to no avail. Seems it is further down the wiring harness, or most likely in the actuator.The tab is on the rocker switch that pushes the plunger
