- Location
- United States
need OEM shifter assemble or if anybody knows of a company that sells the internals of the shifter assembly for rebuild to replace slop .
My shifter is missing the thumb push button... and I didn’t know if that would be part of a rebuild kit it’s a long shot but I felt asking was probably better than trying to find one for 300$you can just replace the 2 bushings on the main cross shaft and that will get rid of most of the play in the shifter
there should be a sticky in the 60/62 tech section
here's one
Loose gear shifter?
how do you tighten up the gear shifter so that it does not shake?forum.ih8mud.com
here's another
The "No Slop" FJ62 shifter mods
After almost 22 years, my 62's shifter was in sad shape. Even with new OEM bushings and proper adjustment per the FSM, it still had a lot of lateral and fore/aft slop. So the other day I decided to take a break from my current projects (and troubleshooting) to tackle this and fix it for good...forum.ih8mud.com
