- Location
- United States
Looking for the necessary parts for a 5spd swap for my 80
Pfa thnx
Pfa thnx
Love a manual in an 80. Good luck.
Here you go
Hzj and an h55Love a manual in an 80. Good luck.
Got a thread or what’s the engine?
Not a worry, nothing electronic will.be neededHere you go
SOLD - Flagstaff, AZ, 1FZFE Manual Transmission ECU and LHD clutch pedal
I am selling a few things for a manual conversion. One item is the extremely hard to find manual transmission 1FZFE OBDII ECU that is required for those doing manual swaps on their 80 series. I bought this for $1200 with the intent to do my own swap but decided not to. I did hook it up in my...forum.ih8mud.com
on edit: on closer inspection, that unit is gone, sorry for not reading the fine print first.
I also have all the parts to do a manual 4 spd swap into 3FE FJ80 (the later 4spd with spacer so an H55f COULD go in its place one day). The clutch pedal/bucket are home fabbed but work. I have driveshafts too. Based on the cleanliness of that shop, you'll probably want the expensive clutch pedal in the post above, and not my homebrewed one.
How about the bucket???Thought i read a couple threads a while back where 60 series pedal assemblies were used in an 80 and worked quite well.
Just a thought.
I'm looking at doing the same thing in the next while.
