i have been searching the threads for sometime now, and can’t find a remedy. In order to install the new runs and or regulator everything seems to say you need to lower the window. How do I lower the window if it is stuck in the up position? When I try to lower the window the battery gauge does jog down, but nothing happens with the glass. Is this a regulator or a guide issue? I have previously taken apart the switch (that spring loaded lock mechanism is a PITA), and cleaned all of the terminals. The window worked perfectly fine, and when we got our first rain since the window has stayed in the up position.
