I am trying to 3 link + panhard the front of my HJ61 and have a few questions. I have read Bellavista's suspension and coil over FAQ and I am gathering data to plug into his formulas to get spring rates and ride heights etc. My goal is to have a great on road driving truck, a good crawler and can haul all our gear that sits relatively low on a set of 37"-39.5".
The problem seems to be that everybody sets their rigs up for super soft suspension and goofy long travel.
I am wanting a dual (or triple ) purpose rig that can do the overland travel, play in the rocks and be a decent daily driver to tow the boat to the lake.
The big one, my truck weighs in at 7500lbs moderately loaded. Should I be looking at 3" CO vs the 2.5" CO? My understanding is the rates are the same but the cooling and fade are affected the bigger you go. Not sure if this applicable to a non race truck?
How much up travel vs down travel and length of coil over does a guy really need. I know this is asked all the time but I have never been satisfied with the answers I see. I am not a buggy, nor am I going to follow one around at the rubicon, but I would like to hold my own. Well as much as a full bodied rig can.
Right now I have a frame height of 21" with 7" of space between axle and frame and about 5" of space between pumpkin and engine. This would safely give me 4.5" of up travel (two on air and 2.5 on air bump stops) I think this is OK.
My other issue that has me concerned is I only have 22" of room at ride height for the coil over. That would limit me to a 10" travel CO. Am I going to be disappointed with 4" up and 6" down???
and a few pictures.
Got links?
Evo joints for the frame end... If the poly bushings don't work out I will replace them with more EVO joints.
3 link calc. These numbers are close but not exact yet. I may have to move the upper link to the other side because of room. Any pitfalls of having the upper link on the oposite side of the pumpkin/drive shaft?
and a few pictures.
Got links?
