Just got my hj60 back from getting new injector tips and the idle feels much faster
In looking at the manual, it says that the 2H with A/C and power steering should have a 2-stage diaphram idle-advance.
I can see a vac line going to what looks to be a VSV then a diaphram. It definitely does *not* kick in when the A/C is engaged. The vsv has 3 ports- two on one side, then one on the other. The line coming out of the one-port side goes to the diaphram. There is only one line attached to the other side.
Anyone know the correct configuration?
Anyone know how the power steering idle-up works?
Any pictures of the correct configuration of the VSV?
I think it would really help out in keeping the cab cooler while idling around ( I spend a lot of time below 1000rpm) but the system is clearly not working right now.
Thanks in advance for any help at all!
